Its stayed like this since 1 hour.
I bought the yesterday
Hi @HK99, welcome to the community.
Try these steps one after the other. Check whether the problem was solved after each step, before trying the next one.
There are no sim cards and memory cards inserted.
Does it have any reset button?
There should be a small yellow button beneath your SIM flap cover, use a non-sharp tool (like a pen tip) to press it until your phone vibrates.
Same issue bro i left it whole night and and after drain full battery again charge and start
Cool, that worked for me, thanks.
Anyway this information should be easier to find, it might be in the notice....
I am glad to hear it is working for you @CocoLasticot
Here's the user guide for the Xperia XA1. https://support.sonymobile.com/global-en/xperiaxa1/userguide/
At the bottom of the list there's troubleshooting, you can find solutions to the most common issues there.
worked for me thanks x
How do I backup my storage when my phone is stuck on the booting screen?
