When I select contact person in contact list, the mobile shows "you have disabled a required permission". I have checked the permission setting and found the contact permission already enabled.
Hi @Patrick1123, welcome to our forum and I'm sorry to hear about this.
Make sure that the Contacts application have the correct permissions, so it can access the storage and so forth.
You can change this in Settings > Apps > Contacts > Permissions. Once the application has all the permissions, try and access it again.
Let me know how it goes!
Hi again @Patrick1123,
I'm glad to hear you were able to solve this and thank you for marking my answer as a solution so other users will have an easier time finding it!
Let me know if there is anything else I may assist you with and have a great day!
Hello,
I have just upgraded my xa ultra to androild 7, and now whenever I try to edit my contacts, it shows you have disabled a required permission.
Even though I have set the contacts app to all permission, still not working, please help. It is really terrible.
Thank you
Thank you for the reply. I have set PHONE and CONTACTS's permissions, but still same problems. any other tips?
Hi @jpproductions, I apologize for the late reply.
That sounds very strange that it keeps asking for a permissions even if you have allowed the contacts application all the available permissions. Could you try clearing data for the Contacts application and you should be asked to give the permissions again once you want to create a contact. You can do so in Settings > Apps & notifications > App-info > Contacts > Storage > Clear data.
This will not delete any saved contacts.
edit: I saw that you are running Android 7, so to clear data, go to Settings > Apps > Contacts > Storage > Clear data.
Let us know how it goes!
thank you for the reply. I have just tried, however, it still not working. After clearing the cache, when I clicked on contacts, it shows the permission windows, where I allow all, however, after that, it still shows you have disabled a required permission.
Any other suggestions?
It is really annoying since I can't add contacts from my phone now
thank you
Hi again!
That sounds very strange, however you wrote that you cleared cache for the application, did you try clearing data as well?
If you have done that and you experience the same behaviour, could you try restarting the device in safe mode and see if there is any change regarding the permissions? Just so we can make sure that no downloaded application is interfering with this as they will be temporarily inactivated in this mode.
