The countdown mini app works normaly. Seems even odder.
The set time dialogue is the same. When i use the mini app the sound works normaly but the screen stays locked. When I use the normal one the opposite...
Thank you guys,
I would still need to fix it. It bothers me. And I a brand new unit...
Out of topic: is it worth upgrading to 5.0
The battery drain scares me
The battery will drain faster the first few days, but it will be ok after, a suggestion, update to lollipop and then re-install it, it smooth things out faster
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
