headphone jack not working
OPGELOST
HaiderAli97
Bezoeker
I recently bought a new Xperia Z1...
Had great time using it but suddenly on one unfortunate day, I found out that the phone no more recognizes any headphone.
I tried to clean the headphone jack.. AND it worked but after 3 minutes, phone wasn't able to recognize headphones not even SONY and beats.
Is it a software issue or something?!
Please help
61 ANTWOORDEN 61
Manasa1
Bezoeker
Hi.. I have been trying to make my head phones work with my Sony Experia z1.. But they haven't worked.. I'm very disappointed.. Few months ago I read ur comment about the app Soundabout and I tried it.. Still it didn't work for me.. Finally today I installed Soundabout again and I did some research on it.. It suddenly worked and I wondered...Thanks for ur information.. Greatwork... I tried to give kudos, but it says some script is missing in my browser..
Direrp
Bezoeker
It's working now
Direrp
Bezoeker
Try this
Go to Settings > Apps > Smart Connect > Press Clear Data and restart phone.
thankyousomuchd
Bezoeker
THANK YOU THANK YOU!!!!!
Thank you!!! i had problem my earphone stopped working i clean it.... and both of them stoped working.... i was desperate... and then you came sir! thank you
Sivasethu
Bezoeker
the solution given by kulveer Singh is very helpfull. but should I need to buy the licensed app.??
Supremeleader
Bezoeker
@kulveer singh, I dont know who you are but bless you man Slightly_smiling_Face
Saramr
Bezoeker
Thank you so much dude. Its working fine for me. Slightly_smiling_Face Slightly_smiling_Face Slightly_smiling_Face
malhargarud
Bezoeker
You're right! I was using SoundAbout for almost 4 months since I was not able to find time to go to the Service Center; Finally, frustrated, I decided to have a look again at the forums, and your solution was the simplest one yet the only one I hadn't tried yet. It worked!! Can't tell you how happy I am! Thanks a lot!
xperiaM4-Aquaus
Bezoeker
this didnt work for me 😞
xperiaM4-Aquaus
Bezoeker
i uninstalled everything that i downloaded. basically did a factory reset and it picked up my headset but only for a few SECONDS
