I purchased the C6602 model mainly to go with T-Mobile HSPA+ but it doesn't seem to work properly. Data speed is extremely slow (50Kbps/100Kbps download/upload) and I only see the letter "E" (for Edge?) instead of H for HSPA on my signal bars.
I've tried all kinds of different APNs but nothing changed. I also tried my sim card on my friend's iphone 4S and it worked perfectly fine with 4Mbps/1.5Mbps download/upload, so the problem must be from the Xperia Z.
Anyone knows how to fix this?
Thanks.
I'd be greatly appreciated if you could share your APN settings thepanttherlady :smileygrin:
I just posted the other screen shot showing the model and what it's running. Have you confirmed that you received model C6602 and not C6603? Please don't take that as an insult to your intellegence it is not intended that way. When I received mine, I didn't open it until I could confirm it was the C6602 and the box is mostly in Japanese! Took me a few minutes to finally find the model # on the box.
If you purchased the phone through Newegg they should be the ones that are responsible for a faulty handset (if you're within the return period), not Sony. I'm sad you're in this predicament.
In case you need to see the other settings I have.
I mean the settings inside that T-Mobile GPRS APN. And yes, the model is C6602 as indicated at the bottom of the phone.
stop by any ATT store, I"m certain that the staff will lend you one of their SIM cards
APN: epc.tmobile.com
Proxy: Not set
Port: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MMC: 310
MNC: 260
Authentication Type: None
APN type: default,supl
APN protocol: IPv4
APN roaming protocol: IPv4
(APN enable/disable is check marked)
Bearer: Unspecified
Just as an FYI, everything is listed in the order as it appears on my screen and all settings are exact including case sensitive (in case it matters).
Yep, tried everthing, still getting Edge. Might have to return for replacement then. Thanks everyone for being so helpful.
@goldbranch, I'm almost certain that you set the APN as they were posted above, but what about Bearer? leave it unspecified and also APN type: default and nothing else. its a long shot but hey its worth the try
