Phone shut down and restarts
dandedoes
Why zo my z3 suddenly shut down and then restarts? I have experienced it several times at about 4-5 o'clock in the night. very disturbing!
1 ACCEPTED SOLUTION
Accepted Solutions
Jake-SonyXperia
Champion
Hi dandedoes,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
There are a number of factors that can cause restarting, in many cases a SIM card or an SD card can be the culprit. I do suggest removing the SIM but also any SD card and try testing to see if the issue continues.
This can also be related to third party applications or apps that may have corrupt data. In such a case removing any new apps would help resolve such an issue.
Finally if none of the above works, then a software repair would be the best option to perform. See the instructions below on how this is done.
  1. Before you start you have to download the PC Companion software from PC Companion
    and install it on your PC.
    2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
    Note! For some models you will be prompted to do a backup prior to the update and then restore.
    3. Install and open PC Companion then select Support Zone.
    4. Phone Software Update.
    5. Start.
    6. Repair Phone
    7. Continue
    8. Accept data removal
    9. Next
    10. Wait for prepare
    11. Select Phone
    12. Follow the connection steps
11 REPLIES 11
Uliwooly
Do you have a regular NANO SIM card or did you trimmed a regular SIM card?
Phy
Legend
Legend
It's probably a Third-party app, you could boot on safe mode for few hours or just repair your phone with PC Companion
Jake-SonyXperia
Champion
Hi dandedoes,
    5. Start.
    6. Repair Phone
    7. Continue
    9. Next
    11. Select Phone
Uliwooly
@dandedoes If you use PCC, don't forget to backup
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
dandedoes
Regular
dandedoes
I have a regular sim card.
The crashes has increased and now my apps suddenly stops. Guess I have to do the hard way and reboot like I have done once before. This didn't happen when I had a iPhone. Android was a bad choice...
Sam
Legend
Legend
We are sorry to hear you feel this way, however I would advise following Jake's advice.
Curnow1
Contributor
@uli is there even a possibility to enter microsim or normall sim to this device?
