Hey guys,
So just as the title says, I cannot power up my phone. Every time I try to power it up, a triangle with a wrench and screwdriver appears with a blue loading screen on the bottom, last for a couple of seconds, then phone shuts down again.
I've had the problem for approximately 5 hours now. I've tried to reset (power button + volume key) it and nothing happens. I believe that everything started yesterday. I was out playing Pokemon GO, and I didn't notice that my battery went down to 0%. The phone shut itself down so I conneted it to a power bank. I powered it back on at ~10% and it shut down again after a couple of minutes (without the battery being drained - at least not visually).
I left the phone shut down in my pocket and when I got home I docked it and everything was fine. Haven't had problems with it all day until the evening. Approximately 5 hours ago I tried to play Pokemon GO again. I turned on data (4G) and location, entered the game and I lost my carrier service (no data). After approximatley 5 seconds the phone shut down and it got EXTREMELY hot in less than 30 seconds.
I've been trying to power it back up/reset it for the past 5 hours. Any ideas what it could be/what can I do?
Thank you!
Yeah, I solved it, but no thanks to this forum.
Changed the battery at a specialized service.
connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours then repair it with XC
Alternatives on How to backup Xperias
An error occurred while repairing your device.
Please try again. If the problem persists, please contact Sony support.
Error code: UEUpdateFailed
UE_2005
Any other solutions?
Any other solutions? You haven't been particularly helpful with your generic reply.
Well? Anyone? Really? Are you guys support technicians or random internet copy-paste posters?
What a... rude... person, I understand your furstration but if you took the time to read about the forum, you will know that this is a user based forum, if you want someone from Sony to assist you, contact them directly >>> Local support
It's not about me being rude, it's about you offering the same generic solution for every problem. That's not what a "person" does, that's what a "bot" does.
I didn't contact Sony's actual support because I thought someone on the forum could come up with a REAL solution, not a generic "please reset your phone because that would solve your problem" - because it's the same solution you give to everyone and then you stop replying to their posts.
I have the same issue you reported. Did you manage to solve it?
Thanks,
Ana
