Podziel się wrażeniami!
Rozwiązane! Idź do rozwiązania.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Sorry to hear that you have issues with small apps.
It's not an issue i've heard of before. Are you using our launcher or are you using a 3:rd party launcher? Which build number do you have under Settings -> About phone?
First try restarting the phone and see if that helps. If not, does the same thing happen in safe mode?
Glad to hear that it works now
Thanks for reporting this!
I will forward this internally for further investigation. Could you also send me a PM with the IMEI of your phone and the build number (Settings -> About phone)?
To remove the smart screen you also need to remove the theme for the cover.
The theme cover is removed, but it still appears when the cover is closed. I will pm you.
I've just received information that this issue will be fixed in the next software update.
