sony Z1 is vibrating in silent mode
zimba
Hi
My Sony will vibrate every time I get a text, email or phone call when it is on silent mode. How do I switch this off please
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
That's good, so its an app that you installed not a pre-loaded app, do you have any notification app, ringtone app, etc?
12 REPLIES 12
Uliwooly
Simple if you unlock the screen lower the volume once it reach vibrate press volume down once more and it will turn it off
you can also pull down the notification bar > quick settings > sound (tap it twice)
zimba
No it doesn't 😞 it says at the top of my screen it is in silent mode
Uliwooly
Ok in that case open the messaging app > menu > settings > notification vibration uncheck it, do the same to other apps
zimba
All unchecked and its still doing it
Uliwooly
Do you see the icon: speaker with an X on top?
zimba
Yes I do
Uliwooly
That doesn't seem right, boot on safe mode and check again
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
zimba
In safe mode it doesn't vibrate but back in normal mode and it is still doing it
Uliwooly
