Xperia ZR(C5502) battery issue
vaisakhcr7
My phone's battery drains soo fast...i updated to 4.3 last week...since then battery drains out very fast..i use DU battery saver pro,greenify and Clean Master...any prob wid dis??
Need urgent help...i am confuced...i purchased ZR becoz of impressive battery results..bt nw am disappointed..pls hlp
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
all those apps do the opposite
stay away from
taskillers, task managers, antivirus, battery apps, cleaning apps, ram apps, booster apps
15 REPLIES 15
Uliwooly
stay away from
vaisakhcr7
So uninstalling dos apps does it??
Nd can u suggest some apps essential for the phone..to remove cache nd ol
vaisakhcr7
How to remove cache nd junk files??
Uliwooly
settings > apps > all > menu > size > tap on the app > clear data or clear cache
stay away from those apps (listed above)
vaisakhcr7
This is the screenshot..any abnormalities??
Uliwooly
This is what I would do
1. reinstall the latest update with SUS or PCC
2. I would NOT install those apps
3. I would wait for 1 week to see any battery improvement
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
vaisakhcr7
Can u suggest some apps for the phone..essential apps??.
