Compare Sony 4Ktv X8000D Vs Computer Monitor
profile.country.US.title
farzan_esk
Hello
i have tv 4k X8000D and that’s very nice
i have plan to buy something for my computer
first of all, i need to know why sony dos not making any Computer Monitor?
Second: what is different between tv and monitor?
Third : how can i use my 49 inch 4k tv for computer and its run multi windows ? I mean Korea companies like awful Samsung or lg in their monitor have an ability that users can full screen 2 program ass well . is there any setting for sony tv ?
4:is there problem to connect HDD external in NTFS format ? because every time I put mi hdd in tv , second time tv only show last files and couldn’t read the new data from hdd and I need format it with tv
Thank you
6 REPLIES 6
Pascale_F
Moderator
Hi farzan_esk,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
farzan_esk
Hi
Did you find anything?
Vanilla_
Contributor
Hi farzan_esk,
I don't think I've come across this model before, I think it's not sold in the UK. But I'll try to answer the questions you listed here:
1. Sony used to make VAIO PCs, but they're no longer manufacturing new PCs now.
2. It depends on what you're planning to achieve here. I can mainly say that a PC monitor can be used mostly for display,  but the TV will be more than just a display. You can use it for multiple other services. Also,  TV screens are usually larger than in PC screens.
3. You can connect your PC using an HDMI cable to the TV. In this case, you'll use the TV just as a monitor.
4. I've tried to look up this, and can see that you can use that with Android TVs. Have a look on this link: https://www.sony.co.uk/electronics/support/articles/00179203
Hope this helps,
Vanilla_
IamNic
Hello @farzan_esk,
if you still use Windows 7 you can check out Mosaico to snap windows to different parts of the screen - for Windows 10 it is a default feature called "Snap": https://youtu.be/Bk8yTBLEj3c?t=15
- Nic
Snapping in Windows 10 is a great way to use your screen real estate more efficiently. Snap has been available in previous versions of Windows, but some improvements have been added. See it action on a Surface 3 running Windows 10. More details: ...
farzan_eska
Hi and thank you for your attention,
Unfortunetly the video from win 10 dos not solve my problem , I want to have 2 program side by side in full screen.
would you please see these images and tell me I can use tv like these example ?
https://pasteboard.co/IT9FkQ4.jpg
https://pasteboard.co/IT9FtCW.jpg
https://pasteboard.co/IT9FEgx.jpg
Thank you.
farzan_eska
Hi
This is old ticket
would you like to open new ticket in this forum?
Thanks
