Can anyone recommend the best picture settings for this tv?
I've not been won over by the out of the box settings.
I'll be watching throight sky hd box
Thanks
Hi there
Unfortunately it is hard to recommend settings, due to differences between environmental factors, such as the brightness of your room compared with someone elses. Also, individual tastes too.
My advice is to create a spreadsheet with the default settings, then slightly change them over time, making note in the spreadsheet, so you can revert back to previous settings if you dont like it. Will also help if/when it comes to factory resetting the TV at a later stage.
Lastly, have a read of this FAQ:
Thanks for your reply - much appreciated. I'll take on board your advice.
You can have a look here:
https://www.youtube.com/watch?v=G_rVqwHdiV0
It's for the 805c but it's should be the same.
