Can anyone HELP.
When I set the recorder to record to the HDD using the EPG Guide, it will record the first programme and then turns the power off.
I have the latest Software installed (Version 1.70)
Have spoken to Sony (Call centre in Cairo) but all they say is do a factory re-set, which I had previously tried with no change, or send the equipment for repair.
May you put some more information? Do you mean that you set more than one timer and all but the first are lost? Afterthe first recording, if you have a look at the timer list, it is empty?
Just to be sure about your problem you should know that:
Hi rooobb,
Thanks for your advice.
Yes, when I set more than one timer, only the first is recorded.
I am going to start again with a factory re-set and then record approx. 3 progs. using the EPG Guide and will follow your advice in looking at the Timer list to see if it is empty.
Will let you know the results.
Hi rooobb,
Did a Factory Re-set and then an Easy Start installation.
Recorded 4 programmes using the EPG Guide.
Each prog. had approx. 30mins. gap in-between recording the next one.
All the progs. were saved.
As you correctly said, the recorder went in to standby and then awoke approx. 1 min. before recording the next prog.
All now appears to be o.k.
Thanks for the help.
You're welcome. I was surprised that it was not working since, in my opinion, the HXD is a great machine unfortunately not supported anymore ...
