Hello, I have a Sony STR-DN1080 connected to a Panasonic TV. Connected to the HDMI inputs of the receiver is a Raspberry Pi running Kodi and an Amazon Fire TV stick.
My problem is that I cannot access the Fire TV stick. When I try to select that input the input will automatically switch back to the Raspberry Pi/Kodi within a few seconds. The problem goes away if I disable HDMI control, but I want this enabled as disabling HDMI control means that I cannot use my TV remote control to control Kodi via CEC any more.
Hi there,
Have you tried a factory reset?
Best wishes,
M
