Hello. I have got the problem, my laptop got on the screen, collored strips along desctop at the few places. I would like to know, what could it be? And is it possible to repair it.
Hello makazio98,
let's first check if it is really a hardware problem:
If you can see the lines in the BIOS, it's a hardware problem. If not, it's software.
If it's hardware, it could be relatively minor - damage to the cable between the mainboard and the display - or major - damage to the display or the graphics chip.
Please note, that for a few VAIO models, there is a known issue with the NVIDIA graphics chip, see:
http://genesis.sony-europe.com/instranet/ccil_sony/selfservice/search.jsp?DocId=53420&l=en_GB
Note: that this is only applicable to the models listed there, it doesn't apply to earlier or later models or other Series.
If your model is listed in the document I linked, contact service. For this particular problem, warranty claims are extended beyond the intial timeframe.
If your model isn't listed in the document, your notebook could be a total economical loss, since the replacement of either the mainboard or the display will almost for sure exceed the value of the unit and won't be economical compared with the purchase price of a new system.
