Why you removed phone shortcut from the lock screen it was very helpful. Please add it in the next update
Hi @buzaidq8y,
After the upgrade to Android 6.0, the shortcut on the Screen lock has been changed from a dialer to a microphone. This is how Google has designed the Screen lock for Android 6.0. However, it's possible to change the shortcut on the Screen lock.
Note! If you change the Screen lock shortcut, you will disable Now on tap.
Hi @buzaidq8y,
I'm sorry to hear that. I'm afraid I don't know why that was the case but I've added a note with this solution in the case related to your chat.
