Audio Description
paulfromcromford
Audio Description
Audio Description
My Sony Bravia has recently started to add Audio Description to several programmes on various channels. I don't want it. How do I stop it?
36 REPLIES 36
Try-er
I just kept trying and then left the TV off for a while (15 mins?) then turned it on and tried again and eventually it worked.
Its ages ago now so I can't recall exactly how may times I tried but I wrote this at the time:
Hi, maybe try again and wait a while before turning the settings back on and then wait a while again to see if it takes effect?
AUTO SERVICE UPDATE - this should be on, CHANGE IT TO OFF, then underneath it, go to:
SOFTWARE DOWLOAD - this should also be on, CHANGE IT TO OFF, then go back to watchin TV for 10 minites
Then turn them both back to ON and wait again...
Hope it works for you......good luck with it!
auto description is set to “off” but still is functioning
JASONBUDGE
I have a KD-65XD8599 running Kernal version 3.10.70. Please help me turn off the extremely irritating narrations (Audio Description) on certain programs. I can't seem to find it in the settings.
Thank you and kind regards
Jason Budge
LilArt
I have recently found a blind and deaf service added to my KDL20S2020 tv
how do I remove?
userof273
There's a button on the remote.
profile.country.US.title
marceya
I can't turn off audio description although it is already set to OFF! HELP.
marceya
This fix didn't stop audio description. Any other ideas?
